The Kapro 787 Series Level Set is a comprehensive and versatile 4-piece toolset designed to meet all your leveling needs with precision and ease. Featuring the renowned Kapro 787 Helius Level, this set is equipped with three solid acrylic shockproof vials—one horizontal and two vertical—ensuring accurate measurements every time. The innovative wall grip feature allows you to hold the level against a flat surface with one hand, preventing scratches or damage to the wall. Additionally, the shock-absorbing rubber end caps protect the level from damage if accidentally dropped.
This 4-piece Kapro 787 Series Level Set includes a range of levels to suit various projects. The Kapro 787 Helius Level 600mm (24
The heavy-duty padded carry bag with a strap is designed for convenience and protection, allowing you to transport your levels easily and safely. The wall grip feature of the levels ensures that you can hold them against a flat surface with one hand, preventing any scratches or damage to the wall. The shock-absorbing rubber end caps protect the levels from damage if they are accidentally dropped, enhancing their durability and longevity.
