The Kapro 108 Plumbing Installation Level is a 28 inch long precision tool designed to simplify plumbing installations with ease and accuracy. Manufactured with two solid acrylic shockproof vials, this level ensures durability and reliable performance in various conditions.
The level features a vertical vial with Kapro's patented plumb side dual view, allowing for direct viewing of the vertical vial without the need to twist or bend your neck. This design ensures easy and accurate readings every time. The horizontal vial includes gradient lines up to 2%, providing precise measurements for various applications.
It is equipped with markers on the profile at standard sink installation points: 280mm for sink attachment to the wall, 150mm for tap placement, and 75mm for water pipes below the sink. These markers simplify the installation process, ensuring accuracy and efficiency. The shock-absorbing rubber end caps on either end protect the level from damage if dropped, enhancing its durability.
Kapro's wall grip feature allows you to keep the level against a flat surface with one hand, preventing scratches or damage to the wall. This feature adds convenience and ease of use, making the Kapro 108 Plumbing Installation Level a reliable tool for any plumbing task.
