The KJD20 230V switch is commonly used on small woodworking machines. Replaces the older KJD6 type switch. Rated at 10amp, it will be suitable for induction motors up to 1hp. Simply connect using insulated spade terminals, the connections being clearly marked for input and output. It is a no-volt-release type of switch, providing safety in the event of an interruption of power. Requires a rectangular hole approximately 22 x 42mm, spring clips holding the switch securely. Fitted with a dust cover with protection of IP54 and having positive action push buttons.
KEDU KJD20-2 Switch 230V 1ph
| Web Attribute Set | Motors & Switchgear |
| EAN Barcode | 5052511046249 |
