The KNIPEX 88 01 Series Alligator® Water Pump Pliers are designed for superior performance and durability. Featuring dipped PVC handles and a box joint design, these pliers prevent slipping from the workpiece. The gripping surfaces have special hardened teeth to approximately 61 HRC, offering high wear resistance and stable gripping.
Made from chrome vanadium electric steel that has been oil-hardened, these pliers provide more output and comfort compared to conventional water pump pliers of the same length. They have a 9-notch adjustment positioning for 30% more gripping capacity. The slim design of the head and joint area allows for good access to the workpiece, and the self-locking feature on pipes and nuts ensures no slipping and low hand force required.
The robust construction of the Alligator® water pump pliers makes them insensitive to dirt, making them particularly suitable for outdoor work. Additionally, the guard prevents the operator's fingers from being pinched.
Length: 250mm (10in)
Pipe Capacity: 50mm
Hex Capacity: 36mm
Length 250 mm
Web Attribute Set Pliers
EAN Barcode 4003773012047
