The KNIPEX 87 Series Cobra® Quickset Hightech Water Pump Pliers are crafted from high-grade vanadium special tool steel, which has been forged and oil-hardened to ensure a longer, robust working life. These pliers combine the proven, reliable locking of the hinge bolt with an additional push function, making it easier to work in very confined and inaccessible areas. The adjustment directly on the workpiece is possible by simply sliding the pliers handle, offering a seamless and efficient user experience.
One of the standout features of these pliers is the reliable locking of the hinge bolt with the first workload. Once the gripping width is fixed, it can only be adjusted by pressing the button, ensuring precision and stability during use. To re-activate the sliding function, the hinge bolt must be released by pressing the push button, and the pliers must be completely opened again. This design provides both ease of use and accuracy, making it a valuable tool for various applications.
The KNIPEX 87 Series Cobra® Quickset Hightech Water Pump Pliers are available with PVC or Multi-Component grips, catering to different user preferences for comfort and control.
Web Attribute Set Pliers
EAN Barcode 4003773073796
