Knipex
KNIPEX Electronic Super Knips® for Optical Fibre 125mm
SKU: 113085
£27.59
£22.99 Excl. VAT
  • Ultra-fine cutting for electronics and fine mechanics
  • Suitable for cutting fibre optic cables
  • Induction-hardened cutting edges, approx. 62 HRC
  • Precisely shaped tips for cutting wires close to a surface
  • Ergonomic multi-component grips for comfort
The KNIPEX Electronic Super Knips® are designed for ultra-fine cutting work, making them ideal for electronics and fine mechanics. These cutters are also suitable for cutting fibre optic cables. They feature ground, very sharp cutting edges without bevel, and the cutting edges are additionally induction-hardened to approximately 62 HRC. The precisely shaped tips allow for cutting wires close to a surface from Ø 0.2mm.
Made from special tool steel and oil-hardened in multiple stages, these cutters have a stainless steel rivet joint for extremely smooth movement, minimizing operator fatigue. The controlled micro cutting edge misalignment ensures precise cutting of even the thinnest wires and a long service life. Fitted with ergonomic multi-component grips, they provide added grip and comfort.
Web Attribute Set Specialist Pliers & Tweezers
EAN Barcode 4003773011996
