The KNIPEX 00 11 04 Profi-Key is a versatile tool designed for all standard shut-off systems in the supply of gas, water, and electricity for technical installations in buildings. It is ideal for use with heating, air conditioning, and ventilation systems, shut-off valves, mains switch-boards, and more. This tool is supplied with a securing chain for easy handling and storage.
The Profi-Key includes 3 square keys (5, 7, and 8mm), 1 triangular key (9-10mm), 1 two-way key (3-5mm), 1 long execution conical square key (6, 7, 8, and 9mm), 1 double-ended bit (slotted 1.0x7mm and PH2), and 1.1/4 bit adaptor.
Web Attribute Set Electricians Tools
EAN Barcode 4003773048954
