Built for accuracy and durability, the Komelon Hi-Vis Gripper Tape Measure features a tough nylon-coated blade with clear metric and imperial graduations. The true zero end-hook ensures precise measurements, while the top blade lock helps keep the blade securely in place during use. Housed in an ergonomic ABS case with a protective rubber grip, it's comfortable to hold and designed to withstand the demands of the workshop and job site. A handy belt clip keeps it close at hand when you're on the move.
Available sizes: 5m (16ft) and 8m (26ft)
Tape Length 5 m
Web Attribute Set Measuring Tapes
EAN Barcode 8803005001933
