{"product_id":"kreg-90deg-pocket-hole-driver","title":"Kreg 90° Pocket-Hole Driver","description":"\u003cp\u003eKreg 90° Pocket-Hole Driver is a compact right-angle driver attachment designed to help you drive screws in tight, hard-to-reach spaces. Perfect for pocket-hole joinery and general assembly work, it turns almost any drill or impact driver into a versatile 90° driving solution.\u003c\/p\u003e\u003cp\u003eThe 90° Pocket-Hole Driver accepts any 1\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e hex shank bit and includes a 75mm #2 square-drive bit with a magnetic tip that securely holds pocket-hole screws during installation. Its ergonomic soft-grip design provides comfortable handling and improved control, while the impact-rated construction stands up to demanding workshop and site use.\u003c\/p\u003e\u003cp\u003eKreg is known for innovative woodworking solutions that help makers achieve stronger joints, cleaner finishes and more professional results with less effort.\u003c\/p\u003e\u003cp\u003eIdeal for cabinet installation, furniture assembly and working in confined spaces, this driver features a 90° drive angle, 1\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e hex bit holder and durable metal housing. Supplied with a 75mm magnetic-tip Robertson (R2) square-drive bit.\u003c\/p\u003e","brand":"Kreg","offers":[{"title":"Default Title","offer_id":54255617835355,"sku":"114933","price":23.48,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114933_xl.jpg?v=1791242038","url":"https:\/\/www.axminstertools.com\/products\/kreg-90deg-pocket-hole-driver","provider":"Axminster Tools","version":"1.0","type":"link"}
