Kreg Accu-Cut™ Circular Saw Track Guide transforms your circular saw into a precision cutting system, allowing you to make straight, accurate and splinter-free cuts in plywood, MDF and other sheet materials. Designed for ripping, crosscutting and angled cuts up to 1,270mm long, it offers a simple and effective way to improve the performance of your existing circular saw without the cost or space requirements of a dedicated track saw.
At the heart of the system is an aluminium guide track and Universal Saw Sled that work together to keep the saw moving accurately along the cut line. Dual anti-slip, anti-chip guide strips help the track stay securely in position without clamps while reducing splintering on veneered and sheet materials. A Starting Block supports the saw at the beginning of the cut, making setup easier and ensuring smooth, controlled blade entry whilst allowing normal blade guard operation. The Universal Saw Sled accepts most left- and right-blade circular saws, making the Accu-Cut™ suitable for a wide range of users and applications.
Constructed from durable aluminium, impact-resistant polymer and rigid and flexible PVC components, the Accu-Cut™ is built to withstand regular workshop and site use. The system provides a cutting capacity of up to 1,270mm and enables accurate, repeatable cuts even when working from sheet edges that are not perfectly straight.
Kreg designs innovative woodworking solutions that help woodworkers achieve professional results more easily. Its range of cutting, joinery and workshop accessories is trusted by both hobbyists and trade professionals for accuracy, reliability and ease of use.
Ideal for cabinet making, fitted furniture projects, workshop tasks and on-site installations, the Accu-Cut™ allows you to take the saw to the material rather than manoeuvring large sheet goods onto machinery.
Supplied with a Universal Saw Sled, two 672mm aluminium guide tracks, two track connectors, a Starting Block, Track Indicator Clip and owner's manual.
Compatible with the Accu-Cut™ XL, Accu-Cut™ Expansion Pack, Accu-Cut™ Replacement Guide Strips, Track Clamps and Rip-Cut™. Not compatible with the Kreg Plunge Saw, not intended for worm drive saws and not recommended for circular saws fitted with plastic upper blade guards.
Rating Trade/Professional
EAN Barcode 647096807177
