Kreg Cabinet Door Mounting Jig provides an extra helping hand when fitting cabinet doors, making installation quicker, easier and more accurate. Suitable for both face-frame and frameless cabinets, it supports left-hand and right-hand doors while allowing precise positioning during hinge installation.
The jig features an adjustable support arm that holds the door securely in place, leaving both hands free for attaching hinges. With nine height settings in 6.35mm increments, it can accommodate inset doors as well as overlay doors up to 51mm. Magnetic micro-adjustment shims allow fine adjustment by 1.6mm or 3.2mm, or can be combined for even greater positioning accuracy.
Kreg is known for innovative woodworking solutions that help makers achieve stronger joints, cleaner finishes and more professional results with less effort.
Ideal for cabinetmakers, kitchen fitters and furniture makers, the Cabinet Door Mounting Jig simplifies door installation and helps achieve consistent results.
Compatible with the Kreg Concealed Hinge Jig and capable of supporting doors weighing up to 11.34kg.
