Create a clean, professional deck finish with the Kreg Deck Jig. This concealed, lightweight fastening system works with Kreg Deck Screws to install decking without visible fixings, leaving a smooth, screw-free surface. Suitable for solid timber and composite deck boards.
The Deck Jig simplifies drilling stepped pilot holes and driving screws in any situation. It features three hardened-steel guides - one positioned at 90° to the board edge and two at opposing 45° angles - providing easy access near walls and allowing strong, secure end-to-end joints. Spacer rings are included to ensure consistent spacing.
The included stepped drill bit forms both pocket and clearance holes in one pass, while a stop collar ensures consistent drilling depth. Drive the Kreg Deck Screw through the same guide using the supplied square-drive bit. The self-tapping, case-hardened screw features aggressive threads for secure joist fixing and a smooth shank to pull boards tight.
Compatible with composite decking, cedar, hardwoods and pressure-treated timber.
Contains 1x deck jig, 1 x deck jig drill bit, 1 x deck jig driver bit, 2 x stop collars, 1 x hex wrench, 3 x spacer rings.
