Kreg Drawer Front Mounting Kit makes it quick and easy to position, align and secure drawer fronts accurately during installation. Ideal for new builds, renovations and repairs, it helps achieve consistent drawer reveals while keeping both hands free for fastening.
Designed for accuracy and stability, the kit features alignment marks, a GripMaxx™ anti-slip surface and heavy-duty steel clamps with ribbed corners to minimise flex. Large adjustment knobs make setup simple, while the included spacer shims can be stacked to create consistent gaps and reveals between drawer fronts. The system works with drawer front overlays up to 38mm per side and drawers with 9.5mm side clearance.
Kreg is known for innovative woodworking solutions that help makers achieve stronger joints, cleaner finishes and more professional results with less effort.
Ideal for cabinet making, furniture projects and kitchen installations, the kit includes a pair of drawer front mounting tools and seven spacer shims (2x 2,4 mm, 2x 3,18 mm, 2x 6,35 mm, 1x 19/38/100.15 mm). Constructed from durable steel and polymer materials, with magnetic shims for easy positioning and adjustment.
