Kreg Drawer Front Mounting Tool Metric simplifies drawer front installation by helping you position, align and secure drawer fronts accurately with minimal adjustment. Designed to reduce fiddly setup, it streamlines the process into three simple steps: clamp, align and attach.
Featuring alignment marks for precise positioning, a GripMaxx™ anti-slip surface for a secure hold and heavy-duty steel construction, this tool helps deliver consistent results. Thick steel components and ribbed corners resist flex, while large adjustment knobs make setup quick and easy. It accommodates drawer front overlays up to 38mm per side and drawers with 9.5mm side clearance.
Kreg is known for innovative woodworking solutions that help makers achieve stronger joints, cleaner finishes and more professional results with less effort.
Ideal for cabinetmaking, furniture building and kitchen installation projects, the Drawer Front Mounting Tool is compatible with Kreg Setup and Spacer Shims (sold separately) for creating accurate, repeatable gaps and reveals. Supplied as a pair of left- and right-hand mounting jigs.
Web Attribute Set Router Jigs & Templates
EAN Barcode 647096811976
