{"product_id":"kreg-foreman-pocket-hole-machine","title":"Kreg Foreman Pocket Hole Machine","description":"\u003cp\u003eThe Kreg Foreman Pocket-Hole Machine is designed to bring fast, consistent and professional pocket-hole joinery into any workshop. Its powerful 230V motor, smooth lever‑controlled action and large working table make it a reliable choice whether you’re batch‑producing components or tackling one‑off builds. With simple tool‑free adjustments, you can set up for materials between 12–38mm thick and achieve accurate pocket-hole depth every time. Clear table markings and spring‑loaded stops help you repeat settings with confidence, keeping your workflow efficient and predictable.\u003c\/p\u003e\u003cp\u003eSupplied with a 3\/8\u003cspecial id=\"32\"\u003e\u003c\/special\u003e stepped drill bit as standard, the Foreman is also compatible with Kreg’s Micro‑Pocket and Heavy‑Duty accessories, giving you the flexibility to produce the right joint for your project. Despite its robust capability, the machine remains surprisingly portable, offering easy movement around the workshop or jobsite. A built‑in accessory tray keeps essential bits close at hand, while the dust extraction port maintains a cleaner, safer working environment.\u003c\/p\u003e\u003cp\u003eFor makers who want accuracy, repeatability and speed, the Foreman delivers pocket‑hole joints with minimal effort and maximum reliability.\u003c\/p\u003e","brand":"Kreg","offers":[{"title":"Default Title","offer_id":54118843777371,"sku":"114163","price":374.98,"currency_code":"GBP","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114163_xl.jpg?v=1789793341","url":"https:\/\/www.axminstertools.com\/products\/kreg-foreman-pocket-hole-machine","provider":"Axminster Tools","version":"1.0","type":"link"}
