Kreg In-Line Clamp provides secure side-pressure clamping without obstructing your work area, making it ideal for assembly, routing, sanding and other bench-based woodworking tasks. Designed to fit standard 19mm bench dog holes, it offers a versatile and efficient clamping solution for workshops and multifunction tables.
Applying pressure from the side rather than above, the In-Line Clamp stays clear of tools and workpieces while delivering up to 113kg of clamping force. The swivelling clamp shoe adapts to a variety of shapes, while the long pushrod provides 121mm of adjustment range. An easy-to-use contoured dial allows quick adjustment, and the lightweight, durable polymer construction ensures long-lasting performance.
Kreg is known for innovative woodworking solutions that help makers achieve stronger joints, cleaner finishes and more professional results with less effort.
Ideal for woodworking benches, multifunction tables and the Kreg Mobile Project Center, the In-Line Clamp fits 19mm and 20mm hole patterns and provides reliable workholding without getting in the way.
Web Attribute Set Quick Clamps
EAN Barcode 647096807542
