The Kreg Pocket-Hole Jig K4 delivers precision, durability, and versatility trusted by DIYers and professionals alike. Its three-hole hardened steel drill guide creates accurately positioned pocket holes in materials from 12mm to 38mm thick and is backed by a lifetime warranty.
A rear-mounted clamp provides exceptional rigidity and holding power with easy adjustment (simply release the locknut and rotate the clamp pad to the correct setting), while the dust collection adapter connects to a vacuum for a cleaner workspace.
Built from impact-resistant polymer, the K4 is designed for long-lasting performance. Wood chip relief holes keep the drill bit clear of debris, therefore reducing drill torque and extending drill bit life. The large clamping recess allows secure bench mounting with face clamps, bar clamps, C-clamps, or direct fastening to your workbench.
Web Attribute Set Power Tool Accessories
EAN Barcode 647096807283
