{"product_id":"kreg-jig-ph-jig-720-plug-cutter-drill-guide-kit","title":"Kreg Jig PH Jig 720 Plug Cutter Drill Guide Kit","description":"\u003cp\u003eKreg Jig PH Jig 720 Plug Cutter Drill Guide Kit allows you to create custom wood plugs that perfectly match your project, providing a neat and professional way to conceal pocket holes. Designed for use with Kreg 700-Series Pocket-Hole Jigs, this kit makes it easy to produce face-grain plugs from virtually any timber for a seamless finish.\u003c\/p\u003e\u003cp\u003eUnlike conventional plugs that expose end grain, the supplied Plug Cutter produces face-grain plugs that blend naturally with the surrounding wood, whether installed with or across the grain. The specially designed cutting tip shears cleanly for smooth, consistent results, while fluting helps reduce heat and friction for improved plug quality and extended bit life. A positive stop collar ensures accurate plug depth every time.\u003c\/p\u003e\u003cp\u003eThe Plug Cutter Drill Guide Block replaces the standard guide block on compatible Kreg 720 and 720PRO Pocket-Hole Jigs, allowing plug blanks to be clamped and drilled using the same simple setup as pocket holes. The Standard Plug Cutter can also accept optional accessory bits for creating Micro-Pocket™ and XL pocket hole plugs.\u003c\/p\u003e\u003cp\u003eKreg designs innovative woodworking solutions that help woodworkers achieve professional results more easily. Its range of cutting, joinery and workshop accessories is trusted by both hobbyists and trade professionals for accuracy, reliability and ease of use.\u003c\/p\u003e\u003cp\u003eIdeal for furniture makers, cabinetmakers and anyone looking to hide visible pocket holes, this kit provides an easy way to create perfectly matched plugs from the same timber used in a project. Supplied with a Plug Cutter Drill Guide Block, Standard Plug Cutter Drill Bit with Stop Collar and Hex Wrench.\u003c\/p\u003e\u003cp\u003eCompatible with the Kreg Pocket-Hole Jig 720, Pocket-Hole Jig 720PRO, and optional Micro and HD Plug Cutting Bits.\u003c\/p\u003e","brand":"Kreg","offers":[{"title":"Default Title","offer_id":54255621308763,"sku":"114943","price":76.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114943_xl.jpg?v=1791242052","url":"https:\/\/www.axminstertools.com\/products\/kreg-jig-ph-jig-720-plug-cutter-drill-guide-kit","provider":"Axminster Tools","version":"1.0","type":"link"}
