{"product_id":"kreg-micro-pocket-drill-guide-kit-730","title":"Kreg Micro-Pocket Drill Guide Kit 730","description":"\u003cp\u003eKreg Micro-Pocket™ Drill Guide Kit 730 is an accessory for the Kreg Pocket-Hole Jig 720 and 720PRO, allowing these jigs to create compact pocket holes for smaller projects, thinner material and repair work. Producing pocket holes 33% smaller in diameter than standard, it is particularly useful when working with stock from 13mm thick and narrow pieces down to 25mm wide.\u003c\/p\u003e\u003cp\u003eThe Drill Guide Block simply fits into the Kreg Pocket-Hole Jig 720 or 720PRO. The stepped drill bit removes less material, making drilling quicker and requiring less effort, while the smaller pocket holes provide a neater solution for more delicate work. Designed for use with Kreg Pan-Head Pocket-Hole Screws (SPS).\u003c\/p\u003e\u003cp\u003eKreg is known for innovative woodworking solutions that help makers achieve stronger joints, cleaner finishes and more professional results with less effort.\u003c\/p\u003e\u003cp\u003eIdeal for furniture making, smaller woodworking projects and repairs, the kit includes a Micro-Pocket™ Drill Guide Block, Easy-Set Micro-Pocket™ Stepped Drill Bit, Easy-Set Depth Adjustment Ring and Material Thickness Gauge with hex wrench. Compatible with Kreg Pocket-Hole Jig 720 and 720PRO.\u003c\/p\u003e","brand":"Kreg","offers":[{"title":"Default Title","offer_id":54255622357339,"sku":"114942","price":53.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114942_xl.jpg?v=1791242057","url":"https:\/\/www.axminstertools.com\/products\/kreg-micro-pocket-drill-guide-kit-730","provider":"Axminster Tools","version":"1.0","type":"link"}
