Achieve clean, precise mortises with these MortiseMate™ Mortising Cutters, designed for use with any drill and the MortiseMate™ Loose Tenon Jig. Engineered for accuracy and durability, the carbide-tipped bit delivers over 5,000 cuts (material dependent), while spiral flutes ensure smooth, clean results ready for loose tenons and strong joints. Laser-etched markings allow quick, accurate depth adjustment, and the included stainless steel stop collar ensures consistent mortise depth up to 25mm (1″).
Constructed with a carbide cutter and stainless steel shank, these cutters create perfectly sized mortises for Kreg tenons and are available in 6 mm, 8 mm, and 10 mm options.
