Carry full-size plywood and sheet materials safely with the Kreg Panel Carrier. Designed for single-person use, it allows you to lift and move 4' x 8' panels with ease. Simply clamp, lift and go.
Slide the pads over the panel and clamp to automatically adjust the material thickness, up to 19mm (3/4″) thick. The Kreg GripMaxx™ pads provide a secure, non-marking hold, protecting delicate veneers and finished surfaces. The ergonomic, padded handle ensures comfortable carrying, while increased lifting pressure tightens the grip to prevent slipping. Carry sheet goods up to 45kg.
Ideal for transporting plywood, MDF and sheet goods in the workshop, on site or from store to vehicle.
Web Attribute Set Dry Lining Tools
EAN Barcode 647096810870
