Kreg Plastic Pocket-Hole Plugs provide a quick and easy way to conceal exposed pocket holes for a cleaner, more professional finish. White in colour these are ideal for white melamine-faced boards, cabinets and furniture projects, these plugs blend neatly with light-coloured surfaces.
Made from durable plastic polymer, the plugs simply press into place and can be fitted with or without glue depending on the application. They can also be used to create a decorative accent where pocket-hole joinery is visible.
Kreg is known for innovative woodworking solutions that help makers achieve stronger joints, cleaner finishes and more professional results with less effort.
Supplied in a pack of 50, these plugs are compatible with Kreg Pocket-Hole Jigs and Kreg Screws. Not suitable for use with the Kreg Pocket-Hole Jig XL.
