The Kreg Pocket‑Hole Jig 320 is a compact, easy‑to‑use solution for creating strong pocket‑hole joints in a wide range of DIY and home workshop projects. Suitable for materials from 13mm to 38mm thick, it offers the flexibility needed for working with common boards and sheet materials, whether you’re building furniture, tackling household repairs or making outdoor projects.
Setup is straightforward thanks to built‑in material thickness stops for 13mm, 19mm and 38mm stock, along with an included thickness gauge and Easy‑Set drill bit with stop collar. Twin drill guides with a removable spacer allow the pocket‑hole spacing to be adjusted quickly, giving greater control when working on different project sizes. An anti‑slip base and supplied clamp adapter help hold the jig securely in position while drilling, ensuring accurate and repeatable results.
Designed to give years of reliable service, the jig features durable construction with hardened steel drill guides backed by a lifetime warranty. All components store neatly in the compact carry case, which also includes space for pocket‑hole screws, making the Pocket‑Hole Jig 320 a practical, all‑round kit for both beginners and experienced woodworkers.
Web Attribute Set Pocket Hole Jigs & Accessories
EAN Barcode 647096809638
