{"product_id":"kreg-pocket-hole-jig-xl","title":"Kreg Pocket-Hole Jig XL","description":"\u003cp\u003eKreg Pocket-Hole Jig XL is designed for creating extra-large pocket holes and exceptionally strong joints in large timber sections. Ideal for 2x4 and 4x4 construction, this heavy-duty jig pairs with Kreg XL Pocket-Hole Screws to deliver joints with outstanding holding power for structural woodworking, outdoor projects and large furniture builds.\u003c\/p\u003e\u003cp\u003eThe jig features hardened steel drill guides that position the XL stepped drill bit at the optimum angle for strong, accurate pocket holes. Dual drill guides are spaced perfectly for common framing timbers but can be separated for greater flexibility when working with larger stock. GripMaxx™ material on the underside helps keep the jig firmly in place during drilling, while the included universal clamping adapter allows it to be secured using Kreg clamps and many other clamp brands. Simple drill bit setup and built-in material adjustment make the system quick and easy to use.\u003c\/p\u003e\u003cp\u003eConstructed with durable hardened steel drill guides, the Pocket-Hole Jig XL is built for long-term accuracy and repeated workshop use. It can be used on timber sections up to 90 x 90mm, making it ideal for heavy-duty joinery applications where standard pocket-hole systems may not provide sufficient strength.\u003c\/p\u003e\u003cp\u003eKreg is known for innovative woodworking solutions that help makers achieve stronger joints, cleaner finishes and more professional results with less effort.\u003c\/p\u003e\u003cp\u003ePerfect for pergolas, workbenches, outdoor furniture, timber framing projects and other large-scale woodworking tasks, the Pocket-Hole Jig XL is supplied with an XL stepped drill bit, depth stop with viewing window, XL screwdriver bit and universal clamping adapter.\u003c\/p\u003e\u003cp\u003eCompatible with Kreg XL Pocket-Hole Screws and the Kreg Pocket-Hole Jig XL Drill Bit.\u003c\/p\u003e","brand":"Kreg","offers":[{"title":"Default Title","offer_id":54255623373147,"sku":"114944","price":55.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114944_xl.jpg?v=1791242061","url":"https:\/\/www.axminstertools.com\/products\/kreg-pocket-hole-jig-xl","provider":"Axminster Tools","version":"1.0","type":"link"}
