{"product_id":"kreg-precision-router-table-lift","title":"Kreg Precision Router Table Lift","description":"\u003cp\u003eThe Kreg Precision Router Table Lift gives you accurate, repeatable control over a table‑mounted router, allowing bit height adjustments and cutter changes to be made entirely from above the table. Designed to replace a standard router table insert plate, it fits all Kreg router tables and many popular alternatives, providing a stable, sag‑resistant platform with smooth, precise movement.\u003c\/p\u003e\u003cp\u003eAt the heart of the lift is a bearing‑guided carriage that raises and lowers the router smoothly and without backlash, ensuring consistent accuracy. Height adjustments are made using the supplied crank from above the table, eliminating the need to reach underneath and making setup quicker and more controlled. A precision indexing ring and micro‑adjustment scale simplify fine adjustments, allowing exact cutter heights to be set and returned to reliably for repeat work.\u003c\/p\u003e\u003cp\u003eThe hard‑anodised aluminium insert plate resists scratches and remains flat over time, while above‑table collet access allows fast, straightforward cutter changes. Designed to fit with most common router motors from 82mm to 107mm in diameter and without the need for pads or adapters, the lift offers broad compatibility and flexibility. Whether upgrading an existing router table, setting up a new system or building a custom table, the Precision Router Table Lift delivers the accuracy and convenience needed for efficient, high‑quality routing.\u003c\/p\u003e","brand":"Kreg","offers":[{"title":"Default Title","offer_id":54118844891483,"sku":"114200","price":294.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114200_xl.jpg?v=1789793445","url":"https:\/\/www.axminstertools.com\/products\/kreg-precision-router-table-lift","provider":"Axminster Tools","version":"1.0","type":"link"}
