The Kreg Precision Router Table Setup Bars are designed to make accurate machine setup faster, safer and more repeatable across a wide range of woodworking tasks. Suitable for use with router tables, table saws and spindle moulders, these bars allow precise height and fence positioning without guesswork, helping achieve consistent results when setting cutters and blades.
Each bar features an exclusive three‑gauge design that supports multiple setup functions. A concave step on the underside straddles the cutter or blade, allowing precise height adjustment, while the stepped top edge can be used to check the depth of completed cuts. The stepped end provides a simple reference for setting the distance between a cutter or blade and the fence, making the bars particularly useful for repeat work and batch setups.
Manufactured from soft anodised aluminium, the setup bars are designed to prevent damage to cutters or blades if accidental contact occurs during setup.
Supplied as a set of seven commonly used sizes, they cover a wide range of applications and store neatly in the included protective case for easy access in the workshop.
Web Attribute Set Router Table Accessories
