Kreg Quick-Flip is a clever dual-action drilling and driving tool that makes it easy to create strong screw joints using Kreg Screws. With a simple flip of the bit, you can drill a pilot hole and counterbore, then switch to driving the screw without changing tools.
Designed for speed and convenience, one end features a drill and countersink combination, while the other has a No.2 square-drive bit designed specifically for Kreg Screws. The impact-rated design is ideal for assembly tasks such as face joining, attaching drawer fronts and general woodworking projects. A rubberised grip provides comfortable handling, while the adjustable drill and countersink ensure consistent results.
Kreg is known for innovative woodworking solutions that help makers achieve stronger joints, cleaner finishes and more professional results with less effort.
Ideal for woodworking, cabinetmaking and furniture assembly, the Quick-Flip features a 1/4 (6.35mm) hex shank for compatibility with standard drill and impact driver bit holders.
Web Attribute Set Pocket Hole Jigs & Accessories
