{"product_id":"kreg-rip-cut-metric","title":"Kreg Rip Cut - Metric","description":"\u003cp\u003eThe Kreg Rip‑Cut turns a standard circular saw into a precise, edge‑guided cutting system for making straight, accurate and repeatable cuts in sheet materials. Designed to work directly from the edge of the board, it removes the need for marking, measuring or following layout lines, allowing you to focus on clean, consistent results. By taking the saw to the material rather than the other way around, it makes breaking down large sheets of plywood, MDF and similar boards easier and more manageable, even when working alone.\u003c\/p\u003e\u003cp\u003eOnce the saw is mounted to the universal sled, which accepts most left‑ or right‑blade circular saws, the Rip‑Cut slides along an aluminium guide rail that follows the straight edge of the workpiece. After a simple one‑time calibration, the built‑in measuring scale allows the cut width to be set accurately up to 610mm. This makes it straightforward to produce multiple pieces to exactly the same size from a single setup, saving time and improving consistency.\u003c\/p\u003e\u003cp\u003eThe oversized, reversible edge guide provides stable control throughout the cut and can be configured for left‑ or right‑handed use. Whether you’re making rip cuts or crosscuts, the Rip‑Cut offers a practical way to achieve workshop‑level accuracy using a portable circular saw.\u003c\/p\u003e","brand":"Kreg","offers":[{"title":"Default Title","offer_id":54118845120859,"sku":"114198","price":43.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114198_xl.jpg?v=1789793469","url":"https:\/\/www.axminstertools.com\/products\/kreg-rip-cut-metric","provider":"Axminster Tools","version":"1.0","type":"link"}
