Create accurate, evenly spaced shelf pin holes with the Kreg Shelf Pin Jig. Designed for precision cabinetry, this durable jig features hardened steel drill guides for straight, level and wobble-free holes. Supplied with a high-quality 5mm brad-point drill bit, it delivers clean, consistent results every time. Guides are set to the standard 32mm (1-1/4″) system, making it ideal for cabinet and furniture construction. Backed by a lifetime warranty.
Suitable for fitting adjustable shelves in new or existing cabinets, the built-in fence ensures fast, accurate alignment with the workpiece edge. Drill six holes in a single setup, or connect a second jig for extended rows while maintaining perfect 32mm spacing.
Additional features of the Shelf Pin Jig support concealed hinge installation and drawer slide fitting in frameless cabinets: moulded alignment marks and an indicator window help align mounting screws for hinge plates at a standard 32mm backspacing. This also helps locate the front fixing hole for drawer runner installation.
The jig also has onboard storage for drill bits.
Contains 1 x jig, 1 x bit, 1 x indicator pin, 1 x hex wrench, 1 x stop collar, 1 x set screw and 4 x 5mm pins.
Web Attribute Set Drilling Guides
EAN Barcode 647096811006
