{"product_id":"kreg-shelf-pin-jig-5mm","title":"Kreg Shelf Pin Jig - 5mm","description":"\u003cp\u003eCreate accurate, evenly spaced shelf pin holes with the Kreg Shelf Pin Jig. Designed for precision cabinetry, this durable jig features hardened steel drill guides for straight, level and wobble-free holes. Supplied with a high-quality 5mm brad-point drill bit, it delivers clean, consistent results every time. Guides are set to the standard 32mm (1-1\/4″) system, making it ideal for cabinet and furniture construction. Backed by a lifetime warranty.\u003c\/p\u003e\u003cp\u003eSuitable for fitting adjustable shelves in new or existing cabinets, the built-in fence ensures fast, accurate alignment with the workpiece edge. Drill six holes in a single setup, or connect a second jig for extended rows while maintaining perfect 32mm spacing.\u003c\/p\u003e\u003cp\u003eAdditional features of the Shelf Pin Jig support concealed hinge installation and drawer slide fitting in frameless cabinets: moulded alignment marks and an indicator window help align mounting screws for hinge plates at a standard 32mm backspacing. This also helps locate the front fixing hole for drawer runner installation.\u003c\/p\u003e\u003cp\u003eThe jig also has onboard storage for drill bits.\u003c\/p\u003e\u003cp\u003eContains 1 x jig, 1 x bit, 1 x indicator pin, 1 x hex wrench, 1 x stop collar, 1 x set screw and 4 x 5mm pins.\u003c\/p\u003e","brand":"Kreg","offers":[{"title":"Default Title","offer_id":54118844399963,"sku":"114180","price":34.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114180_xl.jpg?v=1789793388","url":"https:\/\/www.axminstertools.com\/products\/kreg-shelf-pin-jig-5mm","provider":"Axminster Tools","version":"1.0","type":"link"}
