Kreg
Kreg Straight Edge Guide XL 2,438mm / 8'
SKU: 114196
£80.68
£67.23 Excl. VAT
  • Guided cutting for straight, precise cuts up to 2,438mm (8 feet)
  • Compatible with circular saws, jigsaws and trim routers
  • Cutline indicators for quick, accurate alignment
  • Built-in GripMaxx® clamps secure the guide for stable cutting
  • Durable aluminum construction for long lasting use
The Kreg Straight Edge Guide XL lets you make perfectly straight, precise cuts in sheet goods up to 2,438mm (8 feet) long using a circular saw, jigsaw, or trim router. Its sturdy aluminum guide keeps your tool on track for clean, accurate cuts, while integrated cutline indicators make it easy to align to your pencil marks for precise results every time. Built-in low-profile GripMaxx® clamps securely hold the guide in place, providing stability and confidence while cutting. For smaller projects, the Straight Edge Guide is also available in a 1,219mm (4 foot) version.
Compatible with left and right blade circular saws, jigsaws and trim routers.
Contains 2 x 28 guide rails, 2 x 24 guide rails, 6 x paired connector bars, 2 x cutline indicator arms, adjustable GripMaxx clamp, handle.
EAN Barcode 647096810542
