Kreg Wood Project Clamp with Automaxx® 152mm is a versatile workshop clamp designed for pocket-hole joinery, project assembly and general woodworking tasks. Featuring a 152mm reach and 127mm clamping capacity, it delivers fast, secure clamping with automatic adjustment for different material thicknesses.
Powered by Automaxx® Auto-Adjust Technology, the clamp automatically adapts to varying material sizes with a simple squeeze of the handles, eliminating the need for constant readjustment. Clamping pressure can be fine-tuned using an easy-adjust thumbscrew, while large clamp pads distribute pressure evenly to help prevent surface marking. Heavy-duty steel construction and ergonomic padded grips ensure comfort and durability during regular use.
Kreg is known for innovative woodworking solutions that help makers achieve stronger joints, cleaner finishes and more professional results with less effort.
Ideal for woodworking, joinery and assembly tasks, this clamp offers a 152mm reach and clamps materials up to 127mm thick. Compatible with Kreg Pocket-Hole Jigs, the R3 Clamp Pad Adapter, 300-Series Pocket-Hole Jigs and the Kreg Portable Base.
