{"product_id":"laguna-16-32-drum-sander-wheel-castor-set-4","title":"Laguna 16-32 Drum Sander Wheel Castor Set (4)","description":"\u003cp\u003eUpgrade your Laguna 16-32 Drum Sander with the Wheel Castor Set.  This set of four swivelling lockable 75mm castors are designed to provide seamless mobility and enhanced functionality, ensuring that your sander is always where you need it, when you need it.\u003c\/p\u003e\u003cp\u003eWith effortless mobility, you can easily move your drum sander around your workshop without any hassle. The castors provide smooth and stable movement, allowing you to position your sander precisely where you need it. Once in place, the castors lock securely, ensuring your sander remains stable during operation. This stability is crucial for achieving consistent and accurate sanding results.\u003c\/p\u003e\u003cp\u003eMade from high-quality materials, these castors are built to last. They can withstand the rigors of a busy workshop, providing reliable performance for years to come. The castor set is designed for quick and easy installation, so you can upgrade your sander and get back to work in no time.\u003c\/p\u003e\u003cp\u003eThe casters have a 12.7mm mounting stud and can be used on other machines with open stands.\u003c\/p\u003e\u003cp\u003eSupplied as a set of 4 lockable casters\u003c\/p\u003e","brand":"Laguna","offers":[{"title":"Default Title","offer_id":54118523339099,"sku":"111790","price":63.28,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/111790_xl.jpg?v=1789784103","url":"https:\/\/www.axminstertools.com\/products\/laguna-16-32-drum-sander-wheel-castor-set-4","provider":"Axminster Tools","version":"1.0","type":"link"}
