The Laguna B|Flux Dust Extractor is the perfect solution for maintaining a clean and healthy workspace. This exceptionally well-built, compact and portable extractor is ideally suited for smaller workshops. With its high portability it can easily be moved around a workspace, ensuring that it fits seamlessly into any environment.
One of the standout features of this extractor is the 1 micron pleated filter, which comes standard and includes a cleaning paddle to keep your extractor running at peak performance. This high-efficiency filter captures fine dust particles, ensuring a cleaner and healthier workspace with a high filtration level of 99.7% at 1 micron particle size.
Fitted with a 100mm outlet for connection of your choice of hose and this can be assembled with the inlet facing upwards or downwards to suit your requirements. Quiet running 750 W induction motor equipped with a powerful 229mm steel radial balanced fan. Changing the dust collection bag is quick and easy, thanks to the patented Snap-Band. This innovative feature ensures a seamless and secure attachment of the bag, minimising downtime and keeping your workflow uninterrupted.
Designed with the user in mind, this B|Flux combines a sleek design, convenience and durability to deliver outstanding performance. Its high portability on swivel castors ensures a seamless fit into either a small garage or a large workshop. Built to last, the steel frame ensures that the extractor can withstand the rigors of daily use and, unlike most portable units, the B|Flux feels solid and operates with a low noise rating.
Supplied with 4 swivel castors and plastic bag.
Axminster Tools offers an optional 2-year extended warranty on all Laguna machines, ensuring peace of mind and comprehensive coverage. This extended warranty must be purchased at the same time as your Laguna machine. Please see the warranty link below for more details.
Airflow 884m³/hour (520 cfm) Traditional, 748m³/hour (440 cfm) Realistic
Filter Performance 1 micron
Overall L x W x H 737 x 381 x 1,270mm
Power 750 W
Rating Home Workshop
Sound Power Level LwA [Uncertainty K] 76 dB(A)
Cable Length 1.8 m
Plug Fitted UK 3 pin plug
Web Attribute Set Coarse Dust & Chippings Extractors
EAN Barcode 5052511135417
