{"product_id":"laguna-c-flux-3-cyclone-extractor-415v","title":"Laguna C|Flux 3 Cyclone Extractor 415V","description":"\u003cp\u003eThe Laguna C|Flux 3 Cyclone Dust Extractor is a superior solution for maintaining a clean and efficient workspace. It is excellent for extraction for a single machine, or for use within a ducting system. Similar to the C|Flux 1, it effectively separates heavy waste material from fine dust before the airflow reaches the fan, enabling the fan to operate more efficiently at a consistent speed. This advanced dust extractor is designed with the user in mind, offering a range of features that ensure superior performance and convenience. This high-efficiency particulate air filter with a high filtration level of 99.7% at 1 micron particle size that ensures fine dust particles are captured, providing a healthier working environment.\u003c\/p\u003e\u003cp\u003eOne of the standout features of this extractor is the 1 micron pleated filter, which comes complete with a cleaning paddle. The cleaning paddle makes maintenance a breeze, so you can keep your extractor running at peak performance. The remote control feature adds an extra layer of convenience, allowing you to operate the machine effortlessly from a distance.\u003c\/p\u003e\u003cp\u003eThe design features multiple outlet options, providing versatility and allows you to hook up the extractor to a large machine with ease. The 200mm main outlet is provided with a splitter which converts to three, 100mm outlets. The 100mm outlets can be capped off individually. The chute is designed to maximise airflow, with the fan housed inside a single horizontal plenum, reducing airflow resistance. With a 2.2kW motor and 175 litre capacity, it's ideal for continuous use and reduces the need for frequent emptying.\u003c\/p\u003e\u003cp\u003eThe larger waste is collected in a drum that has an innovative lift system, allowing easy attachment or detachment with a simple lever. The drum, which is octagonal in shape, is raised off the ground and securely seals against the lid. When elevated, the CFLUX3 can be effortlessly move on its four sturdy castors attached to the frame. Once lowered, the drum rests on another set of wheels, making it easy to roll to the desired emptying spot.\u003c\/p\u003e\u003cp\u003eWith this Laguna Cyclone Extractor, you get a powerful, efficient, and user-friendly solution that enhances your workspace and promotes a healthier working environment. Experience the difference with Laguna – the ultimate solution where quality seamlessly meets innovation.\u003c\/p\u003e\u003cp\u003eAxminster Tools offers an optional 2-year extended warranty on all Laguna machines, ensuring peace of mind and comprehensive coverage. This extended warranty must be purchased at the same time as your Laguna machine. Please see the warranty link below for more details.\u003c\/p\u003e\u003cp\u003ePlease ensure that your workshop electricity supply is adequate for these machines. If unsure, seek advice from a qualified electrician. N.B. 32A supply is required, (5 pin, 3 x L, N + E for 415V supply).\u003c\/p\u003e\u003cp\u003eSupplied with remote start handset, 1 collection bag for main drum, 1 collection bag for filter dust.\u003c\/p\u003e","brand":"Laguna","offers":[{"title":"Laguna 1 Year Warranty","offer_id":54118627443035,"sku":"111774","price":2299.98,"currency_code":"GBP","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/111774_xl.jpg?v=1789788465","url":"https:\/\/www.axminstertools.com\/products\/laguna-c-flux-3-cyclone-extractor-415v","provider":"Axminster Tools","version":"1.0","type":"link"}
