Laguna
Laguna Fusion 1 Table Saw Fixed Wheel Assembly
SKU: 111765
€42,00
  • Effortless mobility for easy movement around the workshop
  • Robust construction with high-quality wheels for durability
  • Secure locking mechanism to keep the saw in place
  • Quick and easy installation for immediate use
Upgrade your Laguna Fusion F1 Table Saw with the versatile and convenient Wheel System. Designed to provide effortless mobility, this wheel system allows you to easily move your table saw around your workshop, ensuring flexibility and convenience. Whether you need to reposition your saw for different tasks or simply want to store it away when not in use, the wheel system makes it a breeze.
The wheel system features robust construction, ensuring durability and stability during use. The high-quality wheels glide smoothly over various surfaces, making it easy to manoeuvre your table saw without any hassle. Additionally, the locking mechanism ensures that your saw stays securely in place once positioned, providing a stable and safe working environment.
Installation is quick and straightforward, using the pre-drilled holes, allowing you to set up the wheel system with ease and start enjoying its benefits right away.
Enhance your woodworking experience with the Laguna Fusion F1 Table Saw Wheel System and enjoy the benefits of increased mobility and convenience in your workshop.
Web Attribute Set Saw Bench Accessories
EAN Barcode 5052511135486
