With the Laguna Zero Clearance Throat Plate, you can achieve enhanced precision in your woodworking projects. The zero clearance design allows for cleaner cuts with minimal tear-out, ensuring a professional finish every time. Additionally, this accessory improves safety by reducing the risk of kickback, making your woodworking experience safer and more enjoyable.
Crafted from durable and stable phenolic material, this blank insert has been partially machined on the rear side, ensuring a precise fit. However, for a true zero clearance result, final slotting on your saw is required. Made from high-quality phenolic material, it is built to last, providing long-term reliability and performance. Specifically designed to fit the current Fusion 1, 2, or 3 model Table Saw, this throat plate ensures compatibility and ease of use, making it a valuable addition to your woodworking toolkit.
Upgrade your Laguna Table Saw with this quality optional insert and experience the difference in your woodworking projects.
Web Attribute Set Saw Bench Accessories
EAN Barcode 5052511135493
