{"product_id":"laguna-revo-12-16-lathe-bed-banjo-extension","title":"Laguna Revo 12|16 Lathe Bed \u0026 Banjo Extension","description":"\u003cp\u003eEnhance your Laguna Revo 12|16 Lathe with the Bed \u0026amp; Banjo Extension. This accessory extends the bed length, allowing you to work on longer pieces with ease and precision. It's perfect for larger projects like table legs and spindles, saving you time and effort by reducing the need to reposition your work. The additional banjo provides extra support and stability for your tool rest.\u003c\/p\u003e\u003cp\u003eConstructed from high-quality materials, the Bed \u0026amp; Banjo Extension is durable and reliable, ensuring stability and reducing vibrations. Installation is straightforward, allowing you to integrate it into your lathe setup quickly.  The high-torque motor controller ensures that wood-turners can handle workpieces up to 406 mm (16\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) without stalling or spindle bogging. The spindle adapter features 1\u003cspecial id=\"32\"\u003e\u003c\/special\u003e x 8 TPI threads, accommodating both right-handed and left-handed threaded chucks.\u003c\/p\u003e\u003cp\u003eThe Expansion Set includes a 254mm (10\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) bed extension, a cast-iron swing banjo extension for the tool rest, a spindle adapter and all necessary hardware. This extension can be attached at the end of the bed to increase the centre-to-centre capacity by 250mm, resulting in a total turning length of 660mm. Or to the left of the headstock for outboard turning, allowing a maximum diameter of 409mm.\u003c\/p\u003e\u003cp\u003eUpgrade your Laguna Revo 12|16 Lathe with the Bed \u0026amp; Banjo Extension for increased capacity, enhanced stability, and greater versatility in your woodworking projects.\u003c\/p\u003e","brand":"Laguna","offers":[{"title":"Default Title","offer_id":54136161010011,"sku":"111800","price":110.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/111800_xl.jpg?v=1790004827","url":"https:\/\/www.axminstertools.com\/products\/laguna-revo-12-16-lathe-bed-banjo-extension","provider":"Axminster Tools","version":"1.0","type":"link"}
