The Laguna Revo 18|36 Lathe Copy Pin are the perfect accessory for enhancing your woodturning experience. Designed specifically for the Laguna Revo 18|36 Woodturning Lathe, these copy pins provide precision and ease when duplicating intricate designs and patterns.
Copy pins are essential accessories used with lathes to help woodturners duplicate intricate designs and patterns with precision and ease. They are particularly useful when you need to create multiple identical pieces, ensuring consistency and accuracy in your woodturning projects.
Crafted with high-quality materials, the Laguna Copy Pins ensure durability and long-lasting performance. The lathes are fitted with brackets to accept the locking handles and pins on the headstock and tailstock, making them easy to install and use. Whether you're a professional woodturner or a hobbyist, these copy pins will help you achieve consistent and accurate results every time.
Supplied as 2 pins and locking handles.
Web Attribute Set Woodturning Lathe Accessories
EAN Barcode 5052511135684
