The Laguna Sander Abrasive Wraps are designed to deliver exceptional sanding performance and durability. Created to fit perfectly on the Laguna 16|32 Drum Sander, ensuring a seamless and efficient sanding experience.
Each wrap is crafted from high-quality materials that provide consistent and even sanding, making them ideal for both professional and DIY projects. The wraps are already tapered and easy to install and replace, allowing you to maintain optimal sanding conditions with minimal downtime. Whether you're working on large surfaces or intricate details, the Laguna Sander Abrasive Wraps offer the versatility and reliability you need to achieve a flawless finish every time.
For drum width: 406mm (16
Available to purchase in packs of 4 in 36g, 80g, 120g, 150g, 180g and a mixed pack, containing 36g, 2 x 80g and 120g.
Enhance your sanding capabilities with these premium abrasive wraps and experience the difference in quality and performance.
Also suitable for JET 16-32 & Axminster Professional AP406DS Drum Sander.
