The Laguna V10 Adjustable Bandsaw Stand raises or lowers your machine to a comfortable working height while providing a stable, secure foundation. Built for durability and designed for a precise fit, it helps minimise vibration and keeps your bandsaw, grinder or other machines firmly positioned for smooth, accurate operation. The stand is adjustable between a maximum height of 781mm and a minimum of 609mm. The top mounting surface is 419mm x 273mm and a plate can be added to suit other small footprint machines.
Suitable for the Laguna V10 Bandsaw and Laguna G8 Grinder.
Web Attribute Set Bandsaw Accessories
EAN Barcode 5052511147939
