{"product_id":"laguna-v10-bandsaw-10-230v","title":"Laguna V10 Bandsaw 10\" 230V","description":"\u003cp\u003eThe Laguna V10 Bandsaw is the smallest bandsaw in the Laguna range, making it an excellent choice for hobbyists, serious home users and smaller tasks in trade workshops. Despite its compact footprint, it incorporates many of the features typically found on larger bandsaws, delivering smooth, controlled operation and impressive performance in a space saving package.\u003c\/p\u003e\u003cp\u003eWith a maximum cutting depth of 147mm and a cutting width of 245mm, this bandsaw is perfect for handling a variety of small to medium sized projects in the workshop. The toolless roller blade guide system provides improved control, accuracy and easy setup of the bandsaw.\u003c\/p\u003e\u003cp\u003eThe dual blade viewing window allows you to check both tension and tracking while the machine is running. Additionally, the quick-release blade tension lever makes it easy to change blades without compromising safety and means you can easily release the tension stress on the blade when not in use to help prolong blade life.\u003c\/p\u003e\u003cp\u003eThe solid cast wheels drive the blade through the cut with ease. A wheel brush cleans the surface of the wheel so plenty of grip is maintained on the blade. The upper guide is controlled by a rack and pinion. Simply unlock the screw, raise or lower the guides and then lock in place.\u003c\/p\u003e\u003cp\u003eEquipped with a powerful 750W motor, the bandsaw provides ample power to handle a wide range of tasks. Vibration is kept to a minimum, helping to keep noise levels down and achieves smooth results. A two step pulley is in the lower cabinet for access to the high\/low speed ranges (462 and 1,000 m\/min).\u003c\/p\u003e\u003cp\u003eThe fully adjustable Hi-Lo aluminium fence enhances versatility, allowing for full and precise timber support for both large and small work pieces. The fence is attached to a cast iron knuckle that slides back and forth on a solid steel shaft.\u003c\/p\u003e\u003cp\u003eThe cast iron 350 x 320mm table tilts to 45 degrees with a positive Stop at 90°. In the centre of the table is an anodised aluminium throat plate, with 4 adjusting screws, to ensure a perfect flush fit. A standard 19mm mitre slot and side slot are both featured within the table, for easy attachment of accessories and jigs, plus easy blade introduction. The side slot eliminates the need to remove and reset the rip fence, saving time.\u003c\/p\u003e\u003cp\u003eThe bandsaw is fitted with two dust extraction points: a 63mm dust outlet for connection to an extractor, and an under-table extraction point. The oversized throat plate features perforation holes that allow sawdust to pass through the table and into the quick-release collection tray, where it is drawn towards the lower cabinet dust port. The under-table collection hooks onto a hose and is held securely in place by magnets, making it easy to reposition after a blade change. Four levelling screws allow the throat plate to be easily adjusted for a flush, balanced fit with the table.\u003c\/p\u003e\u003cp\u003eWith onboard tool storage, a small work light built into the frame, this bandsaw makes for a worthwhile workshop staple.\u003c\/p\u003e","brand":"Laguna","offers":[{"title":"Default Title","offer_id":54619714715995,"sku":"114453","price":375.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114453_xl.jpg?v=1793780024","url":"https:\/\/www.axminstertools.com\/products\/laguna-v10-bandsaw-10-230v","provider":"Axminster Tools","version":"1.0","type":"link"}
