{"product_id":"lamello-cabineo-8-m6-panel-17-25mm-insert-100","title":"Lamello Cabineo 8 M6 Panel 17-25mm Insert (100)","description":"\u003cp\u003eCabineo insert nut M6 x 15.3 for 17 to 25mm material thickness, supplied in a pack of 100.\u003c\/p\u003e\u003cp\u003eWith the Cabineo 8 M6, connections can now be created with materials like aluminium, steel or HPL. However, where the thread cannot be cut directly into the substrate, Lamello offers an insert for an even stronger joint. This insert is ideal for detachable corner and dividing panel joints and the installation of fixed shelves or vertical dividers in an already assembled unit. The insert allows easy disassembly and reassembly without loss of joint integrity.\u003c\/p\u003e\u003cp\u003eThe strength could also be further improved. The Lamello inserts are hammered into the dividing panels with a through hole, into which the Cabineo then engages from both sides. This generates an enormous clamping force.\u003c\/p\u003e","brand":"Lamello","offers":[{"title":"Default Title","offer_id":54118394724699,"sku":"106750","price":53.93,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/106750_xl.jpg?v=1789778380","url":"https:\/\/www.axminstertools.com\/products\/lamello-cabineo-8-m6-panel-17-25mm-insert-100","provider":"Axminster Tools","version":"1.0","type":"link"}
