Lamello
Lamello Cabineo Cutter - 12mm
SKU: 103950
£295.68
£246.40 Excl. VAT
  • High quality industrial milling cutter
  • For CNC machines
  • Cuts perfect Cabineo recess
  • 12mm diameter
This is an industrial CNC milling cutter 12mm diameter. The CNC cutting of the recess for the Cabineo body can be done either from the top with a 15mm CNC drill bit or from the side using a CNC milling cutter.
Lamello produce the drill and a choice of cutters to suit the requirements of a variety of CNC machines. Fully dimensioned drawings are available for programming the CNC machine for each of the milling cutters and the drill option.
Web Attribute Set Wood Boring Bits
EAN Barcode 7640149934250
