{"product_id":"lamello-clamex-p-14-flexus-connector","title":"Lamello Clamex P-14 Flexus Connector","description":"\u003cp\u003eThe Lamello Flexus P-14 connectors feature flexible locating pins in place of the rigid locating pins found on the Lamello Clamex P-14. This flexibility allows panels to be brought together at an angle. The ability to bring panels together in this way opens up a whole new range of possibilities and assembly sequences. The flexible locating pins act in exactly the same way, keeping the workpiece in position and in all other respects the Flexus P-14 offers all the advantages of the Clamex P-14. Once installed it is almost totally invisible, only a single 6mm hole shows.  A T-slot is cut using a Lamello Zeta P2 biscuit jointer. The Flexus P-14 has the matching ‘T’ shaped profile and slides into place, no screws or glue are needed. A pivot lever locks the two halves together. The lever is locked using a hexagon key though the 6mm hole forming a very secure joint. Made from fibreglass reinforced plastic with a zinc die-cast lever for strength (tensile fitting strength 1000N = 100kg). Minimum thickness 12mm. Overall size 64 x 13.5 x 9.7mm \/ 57 x 7.5 x 9.7mm. This unique fitting overcomes many design problems.\u003c\/p\u003e","brand":"Lamello","offers":[{"title":"80","offer_id":54118418547035,"sku":"107470","price":115.68,"currency_code":"GBP","in_stock":false},{"title":"300","offer_id":54118418579803,"sku":"107471","price":408.68,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/107470_xl.jpg?v=1789779152","url":"https:\/\/www.axminstertools.com\/products\/lamello-clamex-p-14-flexus-connector","provider":"Axminster Tools","version":"1.0","type":"link"}
