{"product_id":"lamello-clamex-p-14-zeta-connector","title":"Lamello Clamex P-14 Zeta Connector","description":"\u003cp\u003eThis is a truly amazing connector with a host of uses. Lamello has overcome many design assembly problems with this clamping connector; it is almost totally invisible, only a single 6mm hole shows. The Clamex P is a biscuit shaped fitting with a ‘T’ profile that slides in place, no screws or glue are needed. Having a pivot lever and two alignment studs, this lever is driven using a hexagon key though the 6mm hole, locking the fitting together forming a very secure joint. Ideally suitable for connections up to 45\u003cspecial id=\"8\"\u003e\u003c\/special\u003e in 18\/19mm panels and for 90\u003cspecial id=\"8\"\u003e\u003c\/special\u003e connections in 16mm panels. The required slot is cut using a Lamello Zeta biscuit jointer specially developed for this application, cutting the slot and adding the ‘T’ to the bottom using a unique vertical mechanical drive. Made from fibreglass reinforced plastic, lever zinc die-cast for strength (tensile fitting strength 1000N = 100kg). Overall length is 66mm x width 27mm, each half has a depth of 14.5mm and it is 7mm in width (9.7mm o\/a with ‘T’). Supplied as a pack of 80, 300 or 1000.\u003c\/p\u003e","brand":"Lamello","offers":[{"title":"80","offer_id":54117949047131,"sku":"506628","price":115.68,"currency_code":"GBP","in_stock":true},{"title":"300","offer_id":54117949079899,"sku":"506629","price":398.98,"currency_code":"GBP","in_stock":true},{"title":"1000","offer_id":54117949112667,"sku":"506630","price":1269.98,"currency_code":"GBP","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/506628_xl.jpg?v=1789770193","url":"https:\/\/www.axminstertools.com\/products\/lamello-clamex-p-14-zeta-connector","provider":"Axminster Tools","version":"1.0","type":"link"}
