Aligning, connecting and detachable the Clamex S-18 connector is very clever, no need for glue and only a small 6mm hole visible on the whole joint the Clamex system is a great way to joint. Cabinet makers, joiners, carpenters, interior fitters, shop and exhibition fitters and people in the furniture industry would all benefit from using Clamex. These are repeatable, detachable connections without noticeable wear. When on site there is minimal assembly time with full prefabrication possible. It is stackable with no protruding parts on the surface and is easy and efficient to install. There are no additional positioning parts such as dowels or tongues required. Tolerance lateral 0,5 mm (max. 0,75 mm) No torsional movement due to aligning studs.
Made of fibre-glass reinforced plastic with a zinc die-cast alloy lever. Size 66 x 29 x 9mm. Groove can be cut with your biscuit jointer fitted with the Clamex HW blade.
Pack Quantity 18
Web Attribute Set Biscuit Jointer Accessories
EAN Barcode 7640129663606
