The Lamello E20‑L is a self‑clamping biscuit designed to create tight, secure surface joints without the need for clamps, using curved ridges that pull the joint together instantly upon insertion. Ideal for fast, efficient assembly in furniture, framing, and panel work.
This pack contains 80 Lamello E20‑L self‑clamping plates, each engineered to slot into a standard 4mm biscuit groove and automatically clamp the workpieces together with a single strike. Suitable for picture frames, panel extensions and mitered casings.
Lamello is globally recognised for precision joinery solutions that transform woodworking efficiency. Their innovative systems (trusted by professionals in furniture making, interior construction, and on‑site assembly) offer accuracy, speed and long‑term reliability. The E‑Series connectors exemplify this ingenuity by delivering clamp‑free, time‑saving assembly across a wide range of applications.
Specification
Size: 56 × 11.5 × 4 mm
Material: Fibreglass‑reinforced plastic
Groove requirement: Standard 4 mm biscuit groove
Installation: Hammer‑in, self‑clamping action
Quantity: 80 pieces per pack
Compatible tools: Any Lamello biscuit joiner
For optimal workflow, pair with the Lamello Classic X or Top 21 biscuit joiners to cut precise 4mm grooves, or combine with standard Lamello wooden biscuits for mixed‑method assembly.
Web Attribute Set Biscuit Jointer Accessories
EAN Barcode 7640129667277
