The Lamello E20 mixed pack delivers a versatile, self‑clamping joining solution for both surface and edge joints, using curved ridges that pull workpieces tightly together without the need for clamps or drying time. Perfect for rapid, efficient assembly in the workshop or on‑site.
This assortment includes 40 E20‑L plates, which are designed for surface joints such as picture frames, panel extensions and mitered casings. It also contains 40 E20‑H plates that are intended for strong edge joints including drawer boxes, bases and carcass construction. Both versions slot into a standard 4mm biscuit groove and clamp securely with a single hammer strike.
Lamello is a global leader in premium joinery systems, renowned for precision engineering and time‑saving innovations. Their E‑Series self‑clamping connectors are designed to streamline assembly, offering reliable clamping strength, universal biscuit‑joiner compatibility and outstanding performance in both furniture making and site installation
Specification
E20‑L size: 56 × 11.5 × 4 mm
E20‑H size: 23 × 28 × 4 mm
Material: Fibreglass‑reinforced plastic
Groove requirement: Standard 4 mm biscuit groove
Installation: Hammer‑in, self‑clamping action
Contents: 40 × E20‑L, 40 × E20‑H, total 80 plates
Compatible with all Lamello biscuit joiners
Works seamlessly with all biscuit jointers that cut a 4mm groove , can also be used with a 4mm groove cut with a router.
