This connector set forms part of the range of accessories and connectors for the Lamello Invis Mx system. This MX2 is the latest connector with 250kg of clamping force and has with a hard nickel surface for a high quality look. The stud has a deeper set thread making the threading of the screw easier. The two part Invis connector is made up of a stud and jointing element, both 12mm in diameter with a coarse outer thread that will 'bite' into the drilled 12mm hole. The internal threaded stud is 14mm in length and the threaded jointing element is 35mm. Supplied as a pack of 20.
Lamello
Lamello Invis Mx2 Connector Set (14mm Stud)
| Web Attribute Set | Dowelling Jigs & Accessories |
| EAN Barcode | 7640129668816 |
